maxruby
#1 Posted : Sunday, January 20, 2013 5:23:05 PM(UTC)
maxruby
Our Kenmore Elite washer is not changing cycles by itself. When I manually change the cycle, the cycles seem to work. For example, the initial cycle fills up then agitates. Then I turn to just BEFORE the rinse cycle and the water drains. Then I turn to Rinse, and it fills and agitates again, and so on.
What is the problem?
#2 Posted : Monday, January 21, 2013 1:32:27 PM(UTC)
Hello,
Sounds like the problem is a bad timer.
- The timer Part number: 8541110
