Our Kenmore Elite washer is not changing cycles by itself. When I manually change the cycle, the cycles seem to work. For example, the initial cycle fills up then agitates. Then I turn to just BEFORE the rinse cycle and the water drains. Then I turn to Rinse, and it fills and agitates again, and so on.
What is the problem?
