Originally Posted by: jesus freak  ...The belt adjust itself... Even if you do think so, it's better to verify it as described in the earlier attached instructions. Gene.
Gene, The service manual link will not open. I would love to look at it.
You do not need the service manual. On 01/03 I posted the instructions on how to adjust the pump belt special for you.
Sorry Gene. I just saw the link. I'll check that tomorrow.
Thank you!:)
Gene, Sorry to get back so late. Adjusted the belt and all is well. My wife says she still smells rubber from time to time.
Ask your wife to decrease size of loads.
Will do! I sure appreciate you and my local appliance parts store!:)
I continue to have this issue. I have slid the pump as far as it can go to tighten the belt. It works for a while and then stops agitating. In can turn the transmission pulley both ways. If I have the machine running when it is supposed to agitate, I cannot turn the transmission. If I create tension on the belt by holding the motor from moving towards the transmission, the transmission tries to rotate clockwise and the motor gets in a bind and won't turn. Thanks!
