Can not turn on/off any of the switches of the display panel. Only let me change time clock. Display shows PF on all burners. unable to activate the oven switches neither. Is the control board? Is any way to be checked its functionality? Thank you
Hello, Open the control panel. Reconnect the main PCB connector CN10 and CN11 more than two times. If it would not help, replace the main PCB. If it did not fix the problem, replace the control panel. Don't be surprised with such inaccurate instructions. They are provided by LG. - The main PCB Part number: 6871W1N002A
