Ice stops dispencing, I have replaced the auger motor & hex cap (looked a litte worn). I removed the ice bin and ran the auger motor with door open and the motor runs fine for about 10 seconds but starts to bog down and stops running. After a couple mintues of letting is sit it will start up and then quit again. This is a new auger motor I purchase from Parts Select a few weeks ago and still can't figure out what is wrong with it not dispencing the ice properly. Please advise.
Groups: APP Team
Hi, I replaced the capacitor Part number: 65889-4 that was recommended but still having the same problem, it stops dispencing ice. Any other suggestions? Thank you, Julie M. Clanton:confused:
Groups: APP Team
Hi.
Did it work for some time?
Simon.
It will run for about 20 seconds than stops but If I remove the ice bin and hold the button down it will run longer.
Groups: APP Team
HI.
Can you check what is the voltage at the auger motor?
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) HI.
Simon. 110-120 V is what is on the sticker for the auger motor. Julie
Groups: APP Team
Hi, Julie.
I asked you to check the actual voltage at the auger motor wile it's running. You need to use the voltmeter.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, Julie.
Simon. Don't have one. Julie
Groups: APP Team
