ineedhelp52
#1 Posted : Sunday, December 9, 2012 8:12:34 AM(UTC)
ineedhelp52
Washer fills and drains water, but doesnt spin or agitate, i dont want to call a repair guy so he can charge me $75 to tell me whats wrong if its somethin gsimple
sidfink43
#2 Posted : Tuesday, December 11, 2012 4:59:44 PM(UTC)
sidfink43
Your model number is incomplete, but this is a basic Whirlpool top loader, (you can tell because the model number starts with '110') then it sounds like the coupler.
It is a reasonable DIY fix, and if you look up the part here you will find a nice video that will show you how to fix it. It helps, a lot, to have a helper.
ges99
#3 Posted : Monday, December 9, 2013 9:37:39 AM(UTC)
ges99
It fills but I don't know about emptying since I just drained the tub when it wouldn't start a cycle.
sidfink43
#4 Posted : Monday, December 9, 2013 3:24:05 PM(UTC)
sidfink43
Ges99
If you will post a model number and give us a little more detail on the problem and how the machine acts we may be able to help you.
ges99
#5 Posted : Monday, December 9, 2013 3:37:00 PM(UTC)
ges99
My Kenmore washer is model 110.24732300 purchased 8/23/2004. When you set it on any cycle and pull the knob outward the tub will fill. But after that nothing happens: no washing, spinning nor emptying of tub. Thanks ges99?
sidfink43
#6 Posted : Monday, December 9, 2013 4:28:49 PM(UTC)
sidfink43
If you move the dial to the drain part of the cycle and nothing happens than the likely culprit is your lid switch.
You can test it by bypassing the lid switch, and if you need to replace the switch it is an easy fix. See the video on replacing Whirlpool Direct Drive lid switch in the video library here, or go to the lid switch part listing and you should see a link to the video.
