2 Pages12>
csulzbach
#1 Posted : Saturday, November 24, 2012 1:34:07 PM(UTC)
csulzbach
The cooktop, broiler and warming drawer work OK but the oven stopped working. When any of the oven modes are selected, e.g. BAKE, the display shows PREHEAT then switches in just a few seconds to BAKE (it used to stay at PREHEAT until the oven temperature was reached). It then cycles back and forth showing PREHEAT and BAKE, but the oven gas doesn't come on. I'm thinking it may be the oven sensor. The ignitor does not glow red like the broiler ignigtor. Can you help?
Thank you
#2 Posted : Saturday, November 24, 2012 7:02:28 PM(UTC)
What is the complete model number of the range?
csulzbach
#3 Posted : Sunday, November 25, 2012 7:13:35 AM(UTC)
csulzbach
The model number is HGS346UC/01
#4 Posted : Monday, November 26, 2012 12:52:42 PM(UTC)
There are two parts which could cause such problem: the relay board (more likely) and the main control board (less likely). Unfortunately both parts are no longer available.
csulzbach
#5 Posted : Monday, November 26, 2012 2:02:46 PM(UTC)
csulzbach
How can that be? the oven is less than 5 years old. How can those parts not be available. could nt it just be the ignitor?
#6 Posted : Monday, November 26, 2012 3:17:02 PM(UTC)
I understand your feelings. You have to ask Bosch why did they do it to you.
I don't think there is something wrong with the igniter because of the information shown on the display, but you can check it for continuity and measure the voltage to the igniter while the control calls for Bake.
#7 Posted : Monday, November 26, 2012 3:19:25 PM(UTC)
In case if I'm wrong and the problem is a bad igniter:
- The igniter Part number: 492431
Part number: 492431
csulzbach
#8 Posted : Monday, November 26, 2012 4:09:42 PM(UTC)
csulzbach
What should the resistance reading be across the igniter out of circuit? and what should the voltage read in circuit?
Thank you for such a quick response
#9 Posted : Monday, November 26, 2012 4:17:47 PM(UTC)
In such situation the most important test is the voltage to the igniter. The normal reading should be about 120 VAC. Improper voltage reading proves a bad controls.
csulzbach
#10 Posted : Monday, November 26, 2012 4:18:59 PM(UTC)
csulzbach
I also posted a bit of wrong information in my original post about the display. When I turn oven on and select bake then turn knob to 350 degrees. The display stays on preheat at 100 degrees it does not switch back and forth to bake. It just stays on preheat at 100 dergrees. Does this change the possible solution?
Guest (5)
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Gas Oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Malumake 2/2/2014 2:26:10 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
Gas Oven not Heating at all burners OK (Oven Repair (including Ranges and Cooktops))
by tattell 2/7/2012 12:01:59 PM(UTC)
Amana ARGS7650 Gas Oven not heating (Oven Repair (including Ranges and Cooktops))
by reg71 10/28/2010 8:49:05 AM(UTC)
Please Help!! Whirlpool gas oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Rebetimm 7/21/2010 9:24:45 AM(UTC)
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 3/17/2010 4:47:18 PM(UTC)
Gas oven not heating (Oven Repair (including Ranges and Cooktops))
by curtisn 10/3/2009 6:34:59 PM(UTC)
Gas oven not heating at all! (Oven Repair (including Ranges and Cooktops))
by krakka 8/14/2008 3:02:27 PM(UTC)
Older Gas Oven not heating up enough (Oven Repair (including Ranges and Cooktops))
by Meg70 2/10/2008 1:56:14 PM(UTC)
gas oven not heating up like it should (Oven Repair (including Ranges and Cooktops))
by fillhardfarm 1/29/2008 9:47:01 AM(UTC)
Gas Oven Not Heating (Oven Repair (including Ranges and Cooktops))
by defirechief8915 10/24/2007 5:33:28 AM(UTC)
2 Pages12>
