MrJ
#1 Posted : Wednesday, October 24, 2012 3:14:04 PM(UTC)
MrJ
Hi,I have a GE profile spacemaker XL1800 (approx 7yrs old)...it all of a sudden started making a humming noise from the venting fan...it turns on but it seems not to be spinning full speed as b4. Everything else works fine.
I tested both the HV cap and the motor cap and they checked out OK.
I also tested the HV diode and I am getting a high resistance (8k ohms).
Could it be a bad diode that is causing this?
Many thanks in advance,
#2 Posted : Thursday, October 25, 2012 3:06:38 PM(UTC)
Which fan did you mean: the cooling fan (#78 at the diagram) or the exhaust fan (#95 at the diagram)?
BTW, no one of them is connected in any way to any high voltage part of the microwave.
MrJ
#3 Posted : Friday, October 26, 2012 11:48:55 AM(UTC)
MrJ
Gene, I'm referring to #95. thank you
#4 Posted : Friday, October 26, 2012 3:26:22 PM(UTC)
Very likely the problem is a bad motor itself.
- The exhaust fan assembly Part number: WB26X10104
MrJ
#5 Posted : Saturday, October 27, 2012 3:23:48 PM(UTC)
MrJ
is there any quick test I can make to determine if that is it?
#6 Posted : Monday, October 29, 2012 4:00:31 PM(UTC)
You can check it for continuity. Also if you would order the part from APP and it would not fix the problem, you can easy return it.
