Groups:: Registered
Hi,I have a GE profile spacemaker XL1800 (approx 7yrs old)...it all of a sudden started making a humming noise from the venting fan...it turns on but it seems not to be spinning full speed as b4. Everything else works fine.
I tested both the HV cap and the motor cap and they checked out OK. I also tested the HV diode and I am getting a high resistance (8k ohms). Could it be a bad diode that is causing this?
Many thanks in advance,
Which fan did you mean: the cooling fan (#78 at the diagram) or the exhaust fan (#95 at the diagram)? Gene. BTW, no one of them is connected in any way to any high voltage part of the microwave.
Groups:: Registered
Gene, I'm referring to #95. thank you
Groups:: Registered
Originally Posted by: Gene is there any quick test I can make to determine if that is it?
Originally Posted by: MrJ is there any quick test I can make to determine if that is it? You can check it for continuity. Also if you would order the part from APP and it would not fix the problem, you can easy return it. Gene.
