PhilWi
#1 Posted : Friday, October 19, 2012 12:50:42 PM(UTC)
PhilWi
When I select a cycle, but before starting it, I note that both the DRY and COOLING status indicators are lit. After starting the cycle the DRY indicator blinks and the COOLING indicator stays lit. I never hear the burner light. Dryer was last used yesterday when the wife noted the second load did not seem to dry correctly.
Does this indicate a specific fault, or should I just start down the testing path of flame sensor, igniter, high-limit switch etc?
Thanks,
PW
Simon / APP Team
#2 Posted : Friday, October 19, 2012 3:57:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It's sounds like the problem is with the control board.
Very unfortunately I can not be more specific due to the limited access to the manuals (LG brand sold By Sears).
Open the dryer and check if the manual is there. Or order one from Sears.
Run the test.
Simon.
PhilWi
#3 Posted : Sunday, October 21, 2012 7:09:53 AM(UTC)
PhilWi
Simon,
Finally had time to take it apart and test.
Findings:
Igniter: ~200 ohms
Thermostat and high-limit thermostat: ~20 ohms each
Gas valve coils: ~1900 ohms each
FLAME SENSOR: a big fat OPEN - infinite ohms
I noticed when I removed the flame sensor that it rattled.
I don't think it should rattle, but I've never shaken one before.
OK - off to order a flame sensor.
My wife is not happy that a relativey new dryer (about 18 months)
already needs to be repaired!!!
PW
Simon / APP Team
#4 Posted : Monday, October 22, 2012 7:36:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Congratulation on your success. Keep us posted.
Simon.
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Maytag gas dryer will not heat (Dryer Repair)
by jsweeyor 10/2/2012 12:15:23 PM(UTC)
GE gas dryer will not heat (Dryer Repair)
by kthorson 9/27/2012 4:30:00 AM(UTC)
Gas dryer will not heat (Dryer Repair)
by RickWilliams 10/25/2010 11:45:37 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore gas dryer will not heat (Dryer Repair)
by mcclr 10/24/2009 5:51:31 PM(UTC)
by sch8891 10/13/2009 8:26:20 AM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
by Ron S 11/30/2008 1:28:06 PM(UTC)
Whirlpool gas dryer will not heat. (Dryer Repair)
by brae 11/22/2007 5:52:59 AM(UTC)
by retcop320 9/11/2007 3:18:41 PM(UTC)
maytag gas dryer will not heat after initial burn (Dryer Repair)
by Agustin 8/27/2007 3:21:24 PM(UTC)
