Leonard07
#1 Posted : Wednesday, December 5, 2007 10:35:41 AM(UTC)
Leonard07
Dryer has started making noise during operation. Can a dryer be lubricated or is it possibly another problem?
#2 Posted : Wednesday, December 5, 2007 12:39:47 PM(UTC)
Not only "can" - it should be lubricated and cleaned inside at least every other year.
Remove the top panel and the front panel.
Remove the belt (before you remove it, draw a picture how it goes on the motor pulley) and the drum.
Check all drum support rollers. Replace them if worn out. Lubricate if not.
- The part number for the set of two rollers AP3098345
- Here are the break down diagrams for the Whirlpool dryer Model LVE5700W0
Leonard07
#3 Posted : Wednesday, December 5, 2007 1:45:41 PM(UTC)
Leonard07
Thanks, exactly what I needed to know.
