Hello Denman, I have some problem as other. Water do not drain completely. I already did basic troubleshooting like checking for clog. I would suspect a drain flapper, but I would like to get a seconds opinion from specialist. Could you let me know if flapper should close all the way or only partially (about 3/4).... MED5870.pdf (187kb) downloaded 19 time(s). Tech Sheet - W10143265A - WED9600TW0 steam dryer.pdf (573kb) downloaded 88 time(s). LER4634.pdf (126kb) downloaded 8 time(s). Thanks Kamil kambozn attached the following image(s):
I am not 100% sure but it looks like it should close further. I would remove the solenoid and try the flapper without it. Also check if it is slipping on the shaft. |
THIS FORUM IS DEAD!!!!!!! |
Groups: Guests
Drain solenoid for a dishwasher frigidaire part number a model number ffcd 2418uv2a
