Nate Burt
#1 Posted : 12 years ago
Nate Burt
just replaced the door lock assembly and still not working. any chance i got a bad part off the shelf?
thanks
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
What was the original symptoms? What made you decide to replace the door lock?
Please provide the model number.
Simon.
Nate Burt
#3 Posted : 12 years ago
Nate Burt
Symptoms - won't spin, but will drain. Model and serial# both illegible. Every seems to think door lock switch was the culprit
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Check the wire harness between the door lock and the control board, all connections at the control. If there is no error codes, most likely it's the control board. Still a chance for the bad motor control.
Good luck.
Simon.
