207 Pages«<175176177178179>»
ment2b
#1761 Posted : Friday, September 21, 2012 1:05:04 PM(UTC)
ment2b
You are welcome. Hopefully the new heater will fix it. Thank you for the feed back.
OK, success in attaching the photo. Here's the evaporator coils, when panel first removed :
ment2b attached the following image(s):
#1762 Posted : Friday, September 21, 2012 1:11:52 PM(UTC)
Did you take this picture before or after repair?
ment2b
#1763 Posted : Friday, September 21, 2012 1:32:40 PM(UTC)
ment2b
:D :D Very funny Gene!! Of course, before. From my previous post above :
Originally Posted by: ment2b Go to Quoted Post
Took over an hr with a hair dryer to get it all melted.
That's some bunch of frosty !
Philips
#1764 Posted : Friday, September 21, 2012 3:33:29 PM(UTC)
Philips
By setting the freezer temperature control to the coldest position you almost closed the air flow from the freezer into the refrigerator. Using this control you actually operating with the air diffuser. Try to set the refrigerator temperature control to 4 and the freezer temperature control close to warmer position. Measure the temperature in both compartments 24 hours after you change the settings and post the results.
In regards of the problem with the drain from the freezer try to blow some air through the drain line after you defrosted it. Make sure the other end of the drain hose (on the back of the refrigerator) is clean as well.
I have changed the settings and will post results tomorrow. What is the exact method of blowing air through the drain line? Is the drain hose on the back the vertical plastic tube?
#1765 Posted : Friday, September 21, 2012 6:31:48 PM(UTC)
No wonder it did not work.
#1766 Posted : Friday, September 21, 2012 6:36:46 PM(UTC)
Originally Posted by: Philips Go to Quoted Post
...1. What is the exact method of blowing air through the drain line?...
...2. Is the drain hose on the back the vertical plastic tube?...
1. There are no such methods. Use your common sense.
2. Probably. It should come out of the refrigerator body.
ghouseiv
#1767 Posted : Saturday, September 22, 2012 6:09:43 AM(UTC)
ghouseiv
Hi all,
I think I having the same problem as this thread:
Frigidaire Gallery: LGUI1849LF2
Less than a year old
Freezer on top, refrigerator on bottom
Perviously the freezer had frost everywhere and the refrigerator was really warm. So I thought I packed the freezer too much. I put all the food out and manually defrosted the unit for a day. I put all the food back in, turned the fridge back on and everything worked fine for a few weeks.
But recently frost has been building up on the back panel of the freezer again, and the ice cream is frozen solid. The refrigerator section seems ok for now though, but I think eventually I'm going to have the same problem as before.
I tried trouble shooting with the instructions on the first page:
Using a flat screwdriver, slowly turn the shaft in the middle of the defrost timer clock wise until it clicks to switch from the cooling cycle to the defrost cycle.
But looking at the diagram, how do I access the defrost control to test the defrost cycle? Do I have to remove any covering to access it?
Thanks in advance.
#1768 Posted : Saturday, September 22, 2012 12:16:19 PM(UTC)
Is your refrigerator less than a year old?
If this is correct, don't do anything and call Frigidaire for service. Otherwise it can void the warranty.
ment2b
#1769 Posted : Monday, September 24, 2012 2:16:14 PM(UTC)
ment2b
GE model GSS22KGPCWW. ~9 years old.
snipped
Gene, I'm picking up the replacement defrost heater tomorrow (fortunately I bought a lifetime warranty, when I replaced the heater 5 years ago)
There is now a 2 tube heater available for my model. In your experience, is this a better option vs the single tube ? I've now replaced the heater twice in 9 years.
#1770 Posted : Monday, September 24, 2012 2:27:53 PM(UTC)
Yes, the double tube kit is much better. It provides better defrost for shorter time.
Guest (14)
