207 Pages«<174175176177178>»
chihaofu
#1751 Posted : Tuesday, September 18, 2012 2:00:53 PM(UTC)
chihaofu
Did you see frost on the back panel in the freezer?
If you did, then the problem is a faulty defrost system. Go to the first post for the troubleshooting instructions.
If there is no frost, then most likely the problem is a bad damper control.
- The part number for the damper control is AP100860
I have Whirlpol model ET22RKXYW00 Freezer is fine, frige is warm (45-49 F degree)
temperature control set as factory default on freezer and fridge
1.check evaporator coil fan--OK
2.evaporator coil no frost, no ice, check back and under coil fan, no block ice
3.removed separate insulator, clear few ice at left and right corner of air reurn
4.check defrot timer (follow Gene forum to use screw drive clockwise turn, did not hear sizzleing sound,wait 10-15 minutes,
counter clockwise back, I heard click and compressor start)
5.door rubber seal is fine.
6.feel fridge no cold air circle, damper has weak air come out but not cool down fridge
7. any idea?
Thanks,
#1752 Posted : Tuesday, September 18, 2012 2:22:28 PM(UTC)
If there is no frost on the evaporator coils that means there is something wrong with the sealed system.
Pull the refrigerator out of the wall. Remove the front bottom grill and the cover on the back of the refrigerator. Clean the condenser coils and make sure the fan next to the compressor works fine.
If after 24 hours you would not see any improvements, call a certified tech to check the sealed system.
Here are the breakdown diagrams and Replacement parts for Whirlpool ET22RKXYW00 REFRIGERATOR | AppliancePartsPros.com
chihaofu
#1753 Posted : Wednesday, September 19, 2012 6:33:04 AM(UTC)
chihaofu
Gene, thank you very much for your advise, I will followup, have couple questions,
1. I put digital thermostates in refrig upper level, overnight(11PM to 8:AM), temperature is 39 degree,but lower level is 43 degree, in daily regular use, temperature is around 45 (upper and lower), is this normal condition? or something to do with sealed system,
2. In forum, you mention defect damper control??
#1754 Posted : Wednesday, September 19, 2012 4:24:33 PM(UTC)
2. In forum, you mention defect damper control?...
1. Any temperature over 40°F in any section of the fresh food compartment is not good.
2. It can be disputable in case of sufficient temperature in the freezer which you did not mention.
ment2b
#1755 Posted : Thursday, September 20, 2012 1:44:45 PM(UTC)
ment2b
GE model GSS22KGPCWW. ~9 years old.
Fridge warming up, freezer cold with frost on back wall.
Looking at the diagram on this site, there is no defrost timer or thermostat that I can see. There's a main board shown on the sealed syatem diagram and, of course, pcb's for the temp settings in the fresh food door.
To test the heater on this model, do I have to remove the ice maker and dispenser motor or is the back wall cover removable below them.
And, if the heater is good, what to look at next. Thanks
Philips
#1756 Posted : Friday, September 21, 2012 6:42:14 AM(UTC)
Philips
Whirlpool side by side Model ED22DQXBW00, the drain at the bottom of the freezer section keeps getting iced over, refrigerator section not cooling properly. Freezer thermostat set to coldest so that refrigerator section is reasonably cool, but the vent on top left of that section does not blow enough cold air and there is ice forming there. The bottom hole between freezer and refirgerator is open, not blocked, sometimes ice forms there also. Is there some other block in the air circulation between freezer and refrigerator? Is there some type of heater for the defrost system that could be having a problem? TIA for any suggestions.
#1757 Posted : Friday, September 21, 2012 10:25:54 AM(UTC)
You can start the troubleshooting using the instructions from one of our previous threads: http://forum.appliancepartspros...-fridge-temperature.html
- The main control board Part number: WR55X10942
- The defrost heater kit Part number: WR51X10101
- The overtemperature thermostat Part number: WR50X10068
- The thermistor (they all are identical) Part number: WR55X10025
ment2b
#1758 Posted : Friday, September 21, 2012 12:23:26 PM(UTC)
ment2b
Thanks gene !
I checked the defrost heater first because, either way, I needed to get the frost out so the fridge would work before I ordered the part. The panel was easy access and held on with only 2 screws.
Turned out the heater was bad. I was surprised the thing was cooling at all with the amount of frost/ice covering the evaporator coils. This must have been building up for quite some time. Took over an hr with a hair dryer to get it all melted. I had the back grill off so I could soak up all the water that was draining out.
Edit: Picture in my next post below
#1759 Posted : Friday, September 21, 2012 12:29:21 PM(UTC)
By setting the freezer temperature control to the coldest position you almost closed the air flow from the freezer into the refrigerator. Using this control you actually operating with the air diffuser. Try to set the refrigerator temperature control to 4 and the freezer temperature control close to warmer position. Measure the temperature in both compartments 24 hours after you change the settings and post the results.
In regards of the problem with the drain from the freezer try to blow some air through the drain line after you defrosted it. Make sure the other end of the drain hose (on the back of the refrigerator) is clean as well.
#1760 Posted : Friday, September 21, 2012 12:33:06 PM(UTC)
Thanks gene !
I tried posting a pic, but apparently not allowed ??
You are welcome. Hopefully the new heater will fix it. Thank you for the feed back.
