vwforonda
#1 Posted : Tuesday, August 21, 2012 5:54:27 PM(UTC)
vwforonda
We had this oven one year after purchasing it from a 2nd hand store, so we have little history. The oven pilot light comes on when we hit Bake, but it does not ignite. We also smell gas after a minute or two. This is in one of our rental units, so I would like to repair it quickly. Is it most likely the ignitor? Is that something fairly easy for a novice to replace? I would like to do it myself if possible. Thanks for any insight.
#2 Posted : Wednesday, August 22, 2012 2:55:43 PM(UTC)
Most likely the problem is a bad (week) oven igniter.
This job is not too difficult if you know how to handle a simple tools. In order to replace it you have to remove the oven floor and the flame spreader.
- The oven igniter Part number: 5303935066
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
by gplundell@msn.com 4/21/2015 3:33:43 PM(UTC)
by paulgbernard 2/14/2015 3:50:00 PM(UTC)
Oven NOT heating up at all (Oven Repair (including Ranges and Cooktops))
by bkevans88 10/31/2014 6:14:02 PM(UTC)
Oven not heating up right. (Oven Repair (including Ranges and Cooktops))
by clueless78 10/17/2014 2:49:30 PM(UTC)
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 3/18/2014 6:25:03 PM(UTC)
Oven not heating up (Microwave Repair)
by coldoc89 5/9/2013 7:06:35 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
convection oven not heating up to correct temperature (Oven Repair (including Ranges and Cooktops))
by cecelo 1/17/2012 6:57:16 AM(UTC)
oven not heating up (Oven Repair (including Ranges and Cooktops))
by cren722 12/20/2011 1:14:07 PM(UTC)
oven not heating up to temperature (Oven Repair (including Ranges and Cooktops))
by buhr 9/12/2011 11:43:11 AM(UTC)
by doette-56 3/6/2011 4:37:05 PM(UTC)
by rpeters23 2/22/2011 5:17:07 PM(UTC)
