BRYAN BURGER
#1 Posted : Tuesday, August 14, 2012 2:02:31 PM(UTC)
BRYAN BURGER
I am renting a house that has a Kitchenaid refrigerator model #KSRT25CRBL01. The refrigerator works flawlessly. The ice maker will make ice but it fails to dispense the ice. The water dispensor works great. The ice dispensor door will not open. If I force it open the ice will dispense normally. The motor and auger work. There is also a red light flashing in the freezer compartment next to the ice maker on/ off switch. Does anyone have any idea how i can check this out.
#2 Posted : Tuesday, August 14, 2012 3:16:42 PM(UTC)
Hi Bryan,
Remove the ice door motor and check it as described in the attached files. Post the results.
- The ice door motor Part number: W10184813
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRT25CRBL01 REFRIGERATOR | AppliancePartsPros.com
File Attachment(s):
Ice door motor removal.doc (1,027kb) downloaded 21 time(s).
Ice door motor test.doc (65kb) downloaded 24 time(s).
BRYAN BURGER
#3 Posted : Wednesday, August 15, 2012 9:34:27 AM(UTC)
BRYAN BURGER
Gene,
Thanks for the information. I removed the dispenser cover and removed the connector P5 on the core board. I checked the resistance between Pin 1 and pins 2, 3, 5, and 6. All of the readings were between the 45 and 55 ohms. I didn't actually remove the motor will that make a difference? Where can I check next if not.
Thanks,
Bryan
#4 Posted : Wednesday, August 15, 2012 1:04:27 PM(UTC)
Bryan,
If there is nothing wrong with the motor then the problem is a bad dispenser control board.
- The dispenser control board Part number: 2303843
BRYAN BURGER
#5 Posted : Wednesday, August 15, 2012 1:41:30 PM(UTC)
BRYAN BURGER
Thanks,
I will let the owner know. I appreciate your time.
Bryan
#6 Posted : Wednesday, August 15, 2012 1:44:23 PM(UTC)
Sschnei
#7 Posted : Tuesday, November 27, 2012 5:05:24 PM(UTC)
Sschnei
Motor had no voltage, replaced control board and still no ice. Now what?
#8 Posted : Tuesday, November 27, 2012 6:08:59 PM(UTC)
What is the complete model number of the refrigerator?
Did you do any troubleshooting before you replaced the motor?
