One more icemaker problem. I see the suggestion to make sure the water line is not frozen to the icemaker, but I do not know how to access the water line, it is behind the back wall. Any suggestions on how to try to that this?
Also, the icemaker was working fine AFAIK when a drip started in the water dispenser. I replaced the (dual) valve and that solved the water drip but that's when the ice maker stopped working. Tried another valve thinking the new one had a bad valve, but had same results...
There was unharvested ice n the maker, so it was nothing to do with the water line/feed. I thawed the whole thing out with a haridryer and now it is running again, problem solved.
