Cephus
#1 Posted : Thursday, August 9, 2012 1:37:10 PM(UTC)
Cephus
We have a Frigidaire range just under a year old, it's worked fine, except last night it started giving an F10 error. We were not using the oven at the time, just the cooktop. I went through and checked the resistance at the EOC (1124) and at the temperature probe (1120). All of the repair suggestions I've seen so far say that they should be different and, depending on which one is different, what part to replace.
So what do you do when they're both the same and you weren't even using the oven?
It has been extremely hot here lately however, with outdoor temperatures up around 110. Could that have any effect?
Thanks.
#2 Posted : Thursday, August 9, 2012 4:45:24 PM(UTC)
Originally Posted by: Cephus Go to Quoted Post
...It has been extremely hot here lately however, with outdoor temperatures up around 110. Could that have any effect?...
What was the temperature in the room where the range was installed?
Cephus
#3 Posted : Thursday, August 9, 2012 5:11:23 PM(UTC)
Cephus
My wife thinks somewhere between 86-89 degrees. Today, after I reassembled the range, I plugged it in and it immediately gave the F10 error. My wife says that before the error last night, she had just turned on one burner and the bake light came on, things started to flash, then the F10 error went off.
#4 Posted : Thursday, August 9, 2012 5:17:36 PM(UTC)
Sounds like the problem is a bad EOC. If the range is less than a year old, it suppose to be covered under the warranty. Call Frigidaire for repair.
Cephus
#5 Posted : Sunday, August 12, 2012 6:51:04 PM(UTC)
Cephus
Thanks for your help, I've pulled out my warranty information and will give a call to Frigidaire on Monday.
#6 Posted : Monday, August 13, 2012 6:23:43 PM(UTC)
