dwu
#1 Posted : 16 years ago
dwu
Hello,
I found this part is available, but I wonder is it difficult to replace the door switch for this fridge ? I was under the impression that the liners are filled with foam after parts are put in, making it difficult to access the parts.
Anyway, I open the door and no light comes on and the switch has lost its spring so I figured I'd start with the switch.
Can I access the switch by removing a side panel or do I pop the switch out from inside (the liner - it seems fit too hard to do that ) ? Is it easy ?
Thanks & please advise.
woodchuckie
#2 Posted : 16 years ago
woodchuckie
It just pops out with a small screwdriver. Looking at the picture there is a clip on the side of the new one which holds it in place when you put it in.
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 8 years ago
Door switch replacement (Microwave Repair)
by pilotlite 11 years ago
Help with GE Spacemaker Door Switch Replacement (Microwave Repair)
by ssgmail 12 years ago
Affinity door switch replacement (Washer Repair)
by nancybillj 12 years ago
dryer door switch replacement (Dryer Repair)
by noto 14 years ago
Dryer door switch replacement (Dryer Repair)
by BK1 14 years ago
Door Switch Replacement (Dryer Repair)
by gardijon 15 years ago
