Hi All,
Need a lil help. The Door Switch is failing on this model and have ordered part AP4242466 (replacement door switch kit) to replace it. The trouble I'm having is accessing behind cover panel in order to gain access to the door switch in order to swap it out. I was wondering if anyone in the forum has experience with this model or perhaps a diagram of the dryer which will show me the order of what I need to remove to gain access the door switch? Thanks, Gardijon
Originally Posted by: gardijon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi All,
Need a lil help. The Door Switch is failing on this model and have ordered part AP4242466 (replacement door switch kit) to replace it. The trouble I'm having is accessing behind cover panel in order to gain access to the door switch in order to swap it out. I was wondering if anyone in the forum has experience with this model or perhaps a diagram of the dryer which will show me the order of what I need to remove to gain access the door switch? Thanks, Gardijon ------------------------------- Sorry Guys, Pls disregard my initial post, I just found that the top of this unit pops right off for easy access to the door switch. :D
