Well, by the time the weekend has gone by, the temp is back down to 38 degrees. i didn't unplug, but tried not to use that frig so we could keep the door shut.
is unplugging the frig like resetting it? thanks.
Originally Posted by: rgill  ..is unplugging the frig like resetting it?... Yes, it does. Gene.
hi - well, frig worked well for about 3 months. Now, we have a freezer temp at 0 ti -2 and a frig temp that won't go below 48. During the day, 50 and then overnight to 48. We have unplugged it and when we did, i looked at the coils, but, they weren't dusty as we cleaned them 3 months ago.
the ice maker and water doesn't work, the temp is unstable as best. The machine is 7 years old. Is there anything else you can think of to do? i really don't want to invest any more in labor on a service call, but, also don't want to spend the $ on a new frig.
thanks!
Does the fan inside the freezer work properly?
how can i tell if the fan is working? Listening for it? thank you.
Make sure the compressor is on. Open the freezer door and listen to the fan. If you can hear it, check the air flow inside the freezer.
the air is circulating and the fan sounds like its running
Check the air flow in the fresh food compartment.
other than the very narrow oblong space at the front of the frig, where would i check for air flow?
Originally Posted by: rgill  other than the very narrow oblong space at the front of the frig, where would i check for air flow? Check out the attached file. Gene.
