willnise
#1 Posted : Wednesday, June 13, 2012 11:34:51 AM(UTC)
willnise
:(what will cause the motor to hum but will not agitate,it will pump out water and spin,but will not agitate
Simon / APP Team
#2 Posted : Wednesday, June 13, 2012 3:04:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First of all check if the motor will run without the belts.
If the problem is still there - pull out the timer, take the cover off and check all the contacts for burns and discolorations. See if you can clean the contacts with the finest sand paper.
Reassemble and try. Doesn't work - replace the timer.
The timer Part number: 22001255
Here are the breakdown diagrams and Replacement parts for Maytag LAT9304AAE WASHER-TOP LOADING | AppliancePartsPros.com
Thank you. Post the results.
Simon.
PS. You can alwais return any unused parts even if they been installed.
willnise
#3 Posted : Thursday, June 14, 2012 11:40:51 AM(UTC)
willnise
Thank you Simon/APP Team
I took off the belts and the motor just hum,when I turned the shaft and the motor started running but it will not start on it's own.So I think I need a new motor.
Simon / APP Team
#4 Posted : Thursday, June 14, 2012 12:14:54 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the motor but still there is the chance that the timer is bad.
Get both of them and return unused one. The APP will take it back even if you installed it.
Thank you.
Simon.
PS. There is the wiring diagram in the parts breakdown It's #8.
