4 Pages<1234>
jstonge
#21 Posted : Saturday, March 10, 2012 4:32:15 AM(UTC)
jstonge
cybolt, did you ever get this working? We you able to find where the water line comes in behind the recess panel? I have this problem in my GE side-by-side now, and I'd like to run a new water line.
I know this was a while back, but if you remember anything it might really help me. Thanks.
stephstanberry21
#22 Posted : Sunday, June 10, 2012 9:17:37 AM(UTC)
stephstanberry21
My water dispenser hose is broken and water goes everywhere how do I repair it?
#23 Posted : Monday, June 11, 2012 12:10:39 PM(UTC)
Where exactly it's broke?
The model number you posted does not come up. The closest model number I found is ED5CHQXKB04
akamaui
#24 Posted : Sunday, September 30, 2012 10:37:06 AM(UTC)
akamaui
when the inside of the freezer door was taken off to replace a broken line on our GE profile side by side, #TFX27PF,TFT27PF, there was foam covering everything and could'nt figure out how to get to the water line. Does this foam come off or are we unable to replace the broken line?
#25 Posted : Sunday, September 30, 2012 7:56:46 PM(UTC)
Try to carefully clean out your way to the water tube. You probably can remove part of that foam to get to the tube and then reinstall it. Place the new tube as far as possible from the inner door panel.
akamaui
#26 Posted : Sunday, September 30, 2012 8:05:35 PM(UTC)
akamaui
Thanks Gene. It had a small hole in from the bottom of the door area and we put some tape on it today that a guy at Home depot told us to use. So far it stopped the leak. Will update if it does not hold up.
jesse g
#27 Posted : Sunday, December 2, 2012 5:59:07 PM(UTC)
jesse g
need to replace water hose going into door water dispenser for model no.ED25PQXFW01
#28 Posted : Monday, December 3, 2012 1:10:51 PM(UTC)
The instructions are attached to the post. You also can use the instructions from the Q & A section after you'll click on the part number bellow.
- The water tube assembly Part number: 4388152
Here are the breakdown diagrams and Parts for Whirlpool ED25PQXFW01 Refrigerator - AppliancePartsPros.com
File Attachment(s):
Removing the water dispenser fill tube.doc (537kb) downloaded 20 time(s).
mfdpa
#29 Posted : Wednesday, January 16, 2013 5:11:17 PM(UTC)
mfdpa
The water dispenser tube is leaking out the bottom of the door. I need the part number for the replacement tube.
Also the water runs slowly from the spout.
#30 Posted : Thursday, January 17, 2013 1:03:08 PM(UTC)
Hello,
This tube for your refrigerator is not serviceable.
4 Pages<1234>
