FoByFo
#1 Posted : Thursday, June 7, 2012 7:04:34 PM(UTC)
FoByFo
It will take the oven about 30 minutes to heat up to 350. The oven flame doesn't look robust - It looks small. Also, the gas is making a sputtering sound through the oven burner when the oven heat is on. I replaced the dual safety valve. It seemed to help some but not much. It is still sputtering and the flame still looks small. I have checked the lines from the manifold to the burner and they are all clear. What's next?
Thanks.
Simon / APP Team
#2 Posted : Friday, June 8, 2012 1:14:01 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You should check the oven ignitor' s amperage draw. The normal is 3.25amp.If it is less - replace the ignitor. See if you can adjust the burner's orifice.
The ignitor bake Part number: 415504
Part number: 415504
Here are the breakdown diagrams and Replacement parts for Thermador PRG364GDUS GAS RANGE | AppliancePartsPros.com
PS. Is the broil works OK?
Thank you. Post the results.
Simon.
FoByFo
#3 Posted : Monday, June 11, 2012 6:41:49 AM(UTC)
FoByFo
Thank you for the reply. That was exactly the problem. I felt a bit stupid. I posted that query late the evening after fighting that and another unrelated problem all day and I was too tired to think. I did a search the next morning and found the answer you ended up providing here. That was too easy - but not cheap. A clear example of the adage about experience being based on good judgement that is the result of learning from bad judgement.
Thanks again. Have a good day.
Simon / APP Team
#4 Posted : Monday, June 11, 2012 8:16:15 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome. Thank you for sharing with us.
Simon.
Electric Oven Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by deere420 1/30/2017 5:34:03 AM(UTC)
Oven SLOW to heat (Oven Repair (including Ranges and Cooktops))
by Sfs_cds07@yahoo.com 11/23/2016 5:28:28 PM(UTC)
oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ndobois@yahoo.com 10/29/2013 10:55:04 AM(UTC)
GE XL44 Gas Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Vinnyboy6527 12/17/2012 12:17:27 PM(UTC)
Samsung Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by lymansbay 4/19/2011 2:36:56 PM(UTC)
gas oven slow to heat up/achieve desired temperature (Oven Repair (including Ranges and Cooktops))
by FPF 1/1/2011 1:09:12 PM(UTC)
GE XL44 Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by solo12357 12/18/2010 9:49:56 AM(UTC)
Electric oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Fairbob 9/15/2008 5:50:52 PM(UTC)
Oven slow to heat up but broiler works (Oven Repair (including Ranges and Cooktops))
by drcain 12/16/2007 12:03:05 PM(UTC)
Oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ladbroke 12/11/2007 8:43:12 PM(UTC)
