Frank720
#1 Posted : Saturday, June 9, 2012 6:42:43 AM(UTC)
Frank720
I have a Frigidaire Freezer roughly about 5-7 years old. I came home to find a nice large puddle of water in front of the freezer so I emptied everything out and dethawed the freezer. When I turn the unit on, it starts but then shuts off. You can hear the compressor turn on and then off in about a minute.
I do not think that the compressor stays on long enough to produce cold air or if it is just shot. I would appreciate any information that you could provide. I thank you in advance for your expertise.
richappy
#2 Posted : Monday, June 11, 2012 5:01:26 AM(UTC)
richappy
To verify a compressor drawing high current, you need to monitor it's current with an amprobe. A high current, over 10 amp will trip the klixon overload. Confirmation of an overload generally is determined by the compressor restarting after a few minutes.
tommyboy84
#3 Posted : Monday, June 11, 2012 7:19:14 AM(UTC)
tommyboy84
What is the cause of the compressor overload?
richappy
#4 Posted : Monday, June 11, 2012 8:21:55 AM(UTC)
richappy
Internal varnish buildup, mechanical problems, or electrical/burnt windings, or ingestion of non compressables.
tommyboy84
#5 Posted : Tuesday, June 12, 2012 10:19:20 AM(UTC)
tommyboy84
Is there a trouble shooting flowchart for a frigidaire refrigerator that suddenly stopped cooling?
richappy
#6 Posted : Wednesday, June 13, 2012 8:18:35 AM(UTC)
richappy
I just diagnosed it for you, to confirm compressor failure you need to monitor the current with an amprobe.
tommyboy84
#7 Posted : Wednesday, June 13, 2012 9:35:04 AM(UTC)
tommyboy84
My refrigerator did stop freezing /cooling, we had to empty everything out. After two days, it came back on and is working perfectly!!! That's why I asked for the troubleshooting flowchart. The compressor must be fine, it's probably one of the control devises like the thermostat. I just need the order of trouble shooting instructions. Thanks for your help.
#8 Posted : Wednesday, June 13, 2012 10:51:24 AM(UTC)
tommyboy84
You may want to start your own post using "Post New Topic"
especially if your model number is not the same as the original poster.
Your symptoms do sound different re: the compressor was not coming on.
My guess would be that it is the control thermostat.
A flowchart will not really help you since the problem is intermittent.
If it happens again just move the temperature control knob up and down a bit, if it fires up replace the thermostat. A fairly common problem with them is sticking open.
Personally I would just replace it.
Throwing out a bunch of food is just too expensive to not take a gamble on it being the problem.
richappy
#9 Posted : Thursday, June 14, 2012 1:47:47 AM(UTC)
richappy
All the original syptoms pointed to a bad compressor. If you would have given us more data, we could have helped better. A lack of voltage to the compressor during failure whould have steered us toward a bad cold control.
Guest (7)
LG freezer stopped freezing (Refrigerator & Freezer Repair)
by VitekP 4/20/2014 1:58:39 PM(UTC)
fridge not cooling as normal and freezer stopped freezing altogether (Refrigerator & Freezer Repair)
by jknotts44 9/4/2012 11:01:26 AM(UTC)
Frig stopped cooling, freezer stopped freezing (Refrigerator & Freezer Repair)
by redclassic57 12/11/2011 2:17:31 PM(UTC)
Freezer stopped freezing (Refrigerator & Freezer Repair)
by msted 9/8/2010 6:28:35 PM(UTC)
by jandrews 4/1/2010 10:09:10 AM(UTC)
by petemen 11/17/2009 4:52:09 PM(UTC)
by jeffkrol 11/16/2009 11:16:33 AM(UTC)
by sburtzoff 7/12/2009 4:40:10 PM(UTC)
