3 Pages<123
baritone
#21 Posted : Friday, January 20, 2012 7:26:14 AM(UTC)
baritone
Originally Posted by: baritone Go to Quoted Post
tried unplugging it and cleaning it
won't keep food cold freezer won't keep food frozen
#22 Posted : Friday, January 20, 2012 9:06:15 AM(UTC)
Durangler
I am not tired yet.
Though I am already tired of baritone who is hijacking your thread.
Jerry L. Dunnahoo
#23 Posted : Friday, January 20, 2012 7:01:17 PM(UTC)
Jerry L. Dunnahoo
The gurgling noise you heard was the pressures in the sealed system equalizing. This is normal when the compressor is running and gets turned off or the cold control is satisfied. As far as the surge protector is concerned, I have no previous experience with this so am reluntant to respond either way, but can tell you that the ferrite beads work when there is another draw on the circuit that put "noise" in the circuit.(And thier definately cheaper than a surge protector!). =]
Benny Webber
#24 Posted : Friday, June 8, 2012 3:08:42 AM(UTC)
Benny Webber
My refrigerator shuts off. The light is on but the pump is not running. If I turn the refrigerator control switch to off and turn it back on it starts. Also if I tap the bottom of the box inside where the control knobs are located, it starts. It will run for days and then just stop. Talked to a repair man and installed a new switch on the pump in the back of the machine but that did not solve the problem. He said it might be a board or a thermostate issue but I don't want to throw good money down the drain changing parts that work. Any ideas???
#25 Posted : Friday, June 8, 2012 3:19:30 AM(UTC)
Benny Webber
Replacement parts for Whirlpool ED5PHEXRQ00 REFRIGERATOR | AppliancePartsPros.com
Sounds like your thermostat (Item 9 iin Section 3) is sticking open intermittently so tapping close to it or changing it's setting un-sticks it.
I would replace it.
This is a fairly common problem.
Benny Webber
#26 Posted : Friday, June 8, 2012 3:28:25 AM(UTC)
Benny Webber
Thank you, I will try that
Benny Webber
#27 Posted : Thursday, June 14, 2012 12:57:56 AM(UTC)
Benny Webber
Yes... That fixed the problem. Thank you
#28 Posted : Thursday, June 14, 2012 3:09:05 AM(UTC)
You are welcome.
Glad to hear you are up and running.
3 Pages<123
