Have a Whirlpool ED22PW ( 1991) side by side with through the door ice and water--the ice dispenser is slugish closing and drops cubes after the fact--It looks as though it just needs a good cleaning but i can't see how to remove the cover to get access--Please -could anyone advise as to how the front cover is secured?--or is a manual and parts list available? Many thanks for any help--Mel
The front dispenser cover can be removed by inserting a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed. - Here are the break down diagrams for the Whirlpool refrigerator Model ED22PWXAN00Good luck. Gene.
Many thanks Gene--just what I needed---Mel
Thanks, Gene After googling Whirlpool and finding no satisfactory solution to my leaking ice chute problem I discovered reassembly of the trap door spring, plunger & pivot pin easily done once I followed your tip on removal of the front dispenser cover without breaking it. Kindest regards, Bruce32563
Mel and Bruce,
I have a Whirlpool ED25RF refrigerator - it makes plenty of ice,but won't dispense it. Would the solution for the other model of Whirlpool refrigerator work for mine too? Thanks!
Originally Posted by: fblank ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...it makes plenty of ice,but won't dispense it... Can you describe it more detailed please? The model number you posted is incomplete. Verify and repost it please. Gene.
I'm having the same problem. Ice gets made no problem, fills the bucket, but when front is pressed on by a glass the door opens up but nothing turns making the ice fall. It's a Whirlpool Gold, Conquest
Originally Posted by: OhiOkie ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I'm having the same problem. Ice gets made no problem, fills the bucket, but when front is pressed on by a glass the door opens up but nothing turns making the ice fall. It's a Whirlpool Gold, Conquest What is the complete model number of the refrigerator? Gene.
Where would I find that? I looked everywhere but it's probably in plain sight!
