3 Pages<123
#21 Posted : Tuesday, January 8, 2013 2:06:49 PM(UTC)
Using a small flat screw driver, accurately remove the front panel. Behind this panel should be a few screws.
SullyTX
#22 Posted : Saturday, January 26, 2013 1:08:01 PM(UTC)
SullyTX
Trying to get the cover off of the ice dispenser to replaced the water dispenser switch. The cover seems glue in. Any easy suggestions for removal without breaking the plastic cover?
Thanks!
#23 Posted : Saturday, January 26, 2013 3:01:49 PM(UTC)
Check for two screws on the bottom of the frame.
SullyTX
#24 Posted : Saturday, January 26, 2013 3:29:34 PM(UTC)
SullyTX
Haven't quite figured out how we got the cover off. Yay! :D Now we can't figure out how to get it back on.
There are three tabs at the top and then two screws on the bottom. Any advice?
Thank!
#25 Posted : Monday, January 28, 2013 8:08:49 PM(UTC)
Attach the top first.
SullyTX
#26 Posted : Tuesday, January 29, 2013 10:25:08 PM(UTC)
SullyTX
Gene,
Here is what we have tried so far...and DO we ever appreciate all the advice (Yay!):
Tried to reverse the removal process (which was a fluke) by snapping the top part of the dispenser cover into the appropriate slots, but the three clips will not slide under the plastic door cover. Husband cracked the far left clip after applying FORCEFUL pressure, hoping a harder push would work. But I can live with two clips :D if the other two would cooperate.
Used a putty knife to slightly lift the edge of freezer door cover (right above the dispenser) hoping remaining clips would snap in with a little nudge, but nothing.
Currently have the dispenser cover covering the dispensing unit via masking tape. LOL It will have to do until husband comes up with an option that does not include completely remove the freezer door cover (eek!).
Suggestions?
BarbjG
#27 Posted : Tuesday, February 5, 2013 10:29:31 AM(UTC)
BarbjG
OK Sorry for the delay. The gate parts look ok. I don't know how to check the electronic parts.
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 7/11/2023 11:36:45 AM(UTC)
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 7/25/2022 3:46:45 PM(UTC)
kenmore/whirlpool ice dispenser auger motor bad ? (Refrigerator & Freezer Repair)
by bobvance 3/23/2019 3:28:57 PM(UTC)
burning up Whirlpool ice dispenser motors (Refrigerator & Freezer Repair)
by dicktrickle88 6/3/2015 12:05:20 PM(UTC)
Whirlpool Ice Dispenser Problem (Refrigerator & Freezer Repair)
by aggiezg05 3/28/2014 3:57:29 PM(UTC)
Whirlpool Ice Dispenser not dispensing (Refrigerator & Freezer Repair)
by dileas 5/23/2013 11:12:31 AM(UTC)
Whirlpool ice dispenser not working (Refrigerator & Freezer Repair)
by DIM62 1/12/2013 7:44:42 AM(UTC)
Possible Whirlpool Ice Dispenser Leak (Refrigerator & Freezer Repair)
by DJosephSr 11/23/2012 4:21:05 PM(UTC)
Whirlpool Ice Dispenser Repair Kit Compatibility (Refrigerator & Freezer Repair)
by wsb252 3/2/2012 4:39:00 PM(UTC)
whirlpool ice dispenser (Refrigerator & Freezer Repair)
by randc 10/7/2011 3:53:14 AM(UTC)
Whirlpool Ice dispenser door not working (Refrigerator & Freezer Repair)
by commo 2/9/2011 9:25:33 PM(UTC)
Whirlpool Ice dispenser Freeze up (Refrigerator & Freezer Repair)
by tc88 7/21/2010 9:28:55 AM(UTC)
Whirlpool Ice Dispenser Not Working After Relay Replaced?! (Refrigerator & Freezer Repair)
by davehorner 12/10/2009 10:52:55 AM(UTC)
whirlpool ice dispenser chute door wont close (Refrigerator & Freezer Repair)
by tksnyder 5/22/2009 8:54:24 AM(UTC)
3 Pages<123
