22 Pages«<1415161718>»
mbrahmer
#151 Posted : Thursday, May 24, 2012 3:44:44 PM(UTC)
mbrahmer
Not too much; I used a hair dryer to thaw them and it thawed very quickly.
Mark
#152 Posted : Thursday, May 24, 2012 3:58:43 PM(UTC)
Mark,
When I asked how bad it was frozen I meant if the air flow could go through. And what about rest of the coils? How they were covered or they were clean?
mbrahmer
#153 Posted : Thursday, May 24, 2012 4:07:59 PM(UTC)
mbrahmer
Not that bad. I used a hair dryer and the ice melted very quickly.
Mark
mbrahmer
#154 Posted : Thursday, May 24, 2012 4:09:21 PM(UTC)
mbrahmer
Sorry, I missed your last post.
I'd say that some air could get past the coils. Most of the rest of them were clean.
Mark
mbrahmer
#155 Posted : Friday, May 25, 2012 10:35:02 AM(UTC)
mbrahmer
Gene,
I got the evaporator motor test done: voltages are good. When I plugged the motor back in it started running; probably still need to replace it??
Other problem is that the fan in the custom cool section is still not running. I pulled the fan out and it runs with 12VDC applied to it. Other issue is that the wiring harness that came with the fan from you is not the right one: I have no 9 pin connectors on my model. What controls this fan?
Thanks,
Mark
#156 Posted : Friday, May 25, 2012 2:31:56 PM(UTC)
Originally Posted by: mbrahmer Go to Quoted Post
...Most of the rest of them were clean...
Hi Mark,
I'm afraid the problem is there and not the fan in custom cool section. That fan does nothing else but maintain a set temperature in this section only.
The evaporator coils should be about 100% covered with thin frost. If most of them were clean then the sealed system can be low on Freon which causing warmer temperature in both freezer and fresh food compartments. Double check the evaporator coils and post the result.
mbrahmer
#157 Posted : Saturday, May 26, 2012 8:37:39 AM(UTC)
mbrahmer
Gene,
The evap coils have a nice uniform light layer of frost on them this morning; temps in the freezer=0, temp in frige=36.
I need to send the custom cool fan & harness back since I didn't need it. Do I need an RMA or what?
Thanks,
Mark
#158 Posted : Saturday, May 26, 2012 12:53:41 PM(UTC)
Hi Mark,
It's still not clear what is wrong. You have to keep it under control for some more time.
mbrahmer
#159 Posted : Saturday, May 26, 2012 1:14:00 PM(UTC)
mbrahmer
Will do. I have reassembled the FF side and left the freezer apart. Since the evap fan was not running and now it has been for about 24 hours, would you recommend I replace it?
Thanks,
Mark
mbrahmer
#160 Posted : Tuesday, May 29, 2012 8:09:10 AM(UTC)
mbrahmer
Gene,
The frige is working well over the weekend FF @ 37 and FZ @ 0.
What do you think?
The latest numbers are: frige @40 Freezer @ -4 and fan over evap not running; coils are frosted.
Thanks,
Mark
