scottatbhm
#1 Posted : Tuesday, May 22, 2012 12:55:45 PM(UTC)
scottatbhm
I acquired this fridge in its current condition, it's about 18 months old and has been in storage about 8 months. Self diagnostics reports no errors. All lights and LEDs work. Compressor and fan run, but compressor never gets warm/hot. Evaporator coils never get cold and their fans never run. I read the PCB's were sensitive and replaced it with a board I ordered from you, but that didn't help. I'm thinking maybe the compressor relay, would that make sense? Thanks in advance for youe assistance.
scottatbhm
#2 Posted : Wednesday, May 23, 2012 4:29:29 PM(UTC)
scottatbhm
Does that sound like the most likely problem?
richappy
#3 Posted : Thursday, May 24, 2012 3:09:07 AM(UTC)
richappy
Is the compressor vibrating and the condenser coils getting warm. If not, you have a bad start device. If vibrating, you probably have a bad refrigerant leak.
scottatbhm
#4 Posted : Thursday, May 24, 2012 6:06:01 AM(UTC)
scottatbhm
The compressor does vibrate. After 5 minutes of running, none of the lines out of the compressor are warm. I checked continuity from the three contacts on the starter relay to the compressor body and they all showed open. I checked between the contacts themselves and they all showed continuity. Freon leak?
richappy
#5 Posted : Thursday, May 24, 2012 12:16:27 PM(UTC)
richappy
Sure seems like a bad compressor/refrigerant leak.
Freeze: compressor runs but no cooling (Refrigerator & Freezer Repair)
Belarus BlueberryFreezer 5/20/2012 2:03:42 PM(UTC)
