nanette4060
#1 Posted : 13 years ago
nanette4060
Ice maker overflowing water when it's in the process of filling for next ice batch. Water overflows then seizes. it does it every time it makes the ice. it fills up to make the ice then it overflows, then it stops, makes the ice, then it fills up to make the ice for the next batch and then the cycle starts all over. Can I repair this myself? What parts do I need, and is there instructions for this.
#2 Posted : 13 years ago
If it's overflowing then the problem is a bad water inlet valve.
If the ice maker itself is leaking water, then the ice maker has to be replaced.
- The water inlet valve Part number: 241803701
- The ice maker Part number: 5303918277
timmer23
#3 Posted : 13 years ago
timmer23
I just replaced the ice maker.works great. ice will dispense crushed on both cube and crushed settings.
#4 Posted : 13 years ago
Remove the ice container and the motor cover (#20 at the diagram). Check the solenoid (#45) for continuity.
Tape in the light switch. Remove the wires from the solenoid and connect the voltmeter probes to them. Check for 120 VAC between these wires while the ice dispenser calls for cubed and crushed ice.
Post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire FRS22ZRGW3 Frg(v3) / Refrigerator | AppliancePartsPros.com
Ice Maker Problems - Whirlpool (Refrigerator & Freezer Repair)
by tomkarl419 3 years ago
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 4 years ago
Whirlpool In Door Ice maker Problems (Dishwasher Repair)
GE Ice Maker Problems (Refrigerator & Freezer Repair)
by GM1123 10 years ago
GE Arctica Side-by-Side Ice Maker Problems (Refrigerator & Freezer Repair)
by coondog 12 years ago
by K7527 12 years ago
by ejg593 12 years ago
I bet you get tired of seeing threads titled "Ice maker problems" (Refrigerator & Freezer Repair)
by highdensity10 12 years ago
Ice maker problems (Refrigerator & Freezer Repair)
by vernjust 12 years ago
Samsung Ice Maker problems (Refrigerator & Freezer Repair)
by bjc7 14 years ago
by emenemenem 14 years ago
Ice Maker problems again after replacing parts (Refrigerator & Freezer Repair)
by hooliek 14 years ago
by luiV 14 years ago
ice maker problems-help (Refrigerator & Freezer Repair)
by gramm 14 years ago
ice maker problems (Refrigerator & Freezer Repair)
by pollyboone@roadrunner.com 15 years ago
