paulbuscema
#1 Posted : Sunday, May 20, 2012 7:21:33 PM(UTC)
paulbuscema
Oven does not go high enough in temp. In the prebake mode, the oven seems to stop at 200 degrees. I can never go above that temp even though the oven senses it is at the right temp
#2 Posted : Monday, May 21, 2012 6:10:59 PM(UTC)
The model number you posted is incomplete. Verify and repost it please.
paulbuscema
#3 Posted : Monday, May 21, 2012 7:18:59 PM(UTC)
paulbuscema
JBP45WS1Wh
#4 Posted : Tuesday, May 22, 2012 3:12:54 PM(UTC)
Ohm out the oven sensor. The normal reading is 15 Ohms @ 70°F.
If the reading is incorrect, replace the oven sensor.
If the reading is correct, the problem is a bad oven control board. Unfortunately this part has been discontinued.
- The oven sensor Part number: WB21X158
paulbuscema
#5 Posted : Friday, May 25, 2012 2:46:19 PM(UTC)
paulbuscema
Thank you for your help. The sensor is good. Oh well-time to look for a new oven. Your help was very valuable.
