Clubogilvie@yahoo.com
#1 Posted : Thursday, March 26, 2009 12:03:07 PM(UTC)
The stove burners work just fine but the oven will not light. The ignitor is glowing hot so I'm guessing that it is the valve-safety but I'm not sure and it's over $100.00. I've also been told that even if the Ignitor-oven gets hot it may not be sending the signal to the valve-safety and it's a $40.00 part so I really want to make sure before I buy a part.
Thank you
TechnicianBrian
#2 Posted : Thursday, March 26, 2009 4:51:37 PM(UTC)
TechnicianBrian
The only way to know for sure would be to use an amp probe to determine the current draw of the igniter. I wrote about this in a post Jenn-Air Gas Oven not Heating Properly where I talk about how the igniter works and how to test it. If you don't have a way to test the igniter, you are left taking an educated guess. Mine would be an igniter failure.
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
