Silvernick
#1 Posted : Tuesday, May 15, 2012 8:20:59 PM(UTC)
Silvernick
I have a GE Range, model number JGSP44AEV3AA. The oven has quit heating. The broiler and all burners work normally. The oven ignitor glows white with heat so it appears to be working but I don't know how to test it. Any idea what may have failed or any troubleshooting steps I should take?
Thank you
#2 Posted : Wednesday, May 16, 2012 3:17:15 PM(UTC)
Very likely the problem is a bad (weak) igniter. You can check it by measuring the current drawn by the igniter. If it's less than 3.2 amps, replace the igniter.
- The igniter Part number: WB13T10001
Silvernick
#3 Posted : Saturday, May 19, 2012 10:30:56 PM(UTC)
Silvernick
Thanks for your response.
I don't have an amp meter and am considering replacing the ignitor without testing it since the meter would probably cost about as much or more than the ignitor does. Does this sound like a good way to go?
If I were to purchase a meter, is there a certain type or model I should get?
Thank you,
#4 Posted : Monday, May 21, 2012 4:01:02 PM(UTC)
Originally Posted by: Silvernick Go to Quoted Post
...Does this sound like a good way to go?...
Yes, it does. Especially because you can return the part if it would not fix the problem.
Silvernick
#5 Posted : Monday, May 21, 2012 5:53:35 PM(UTC)
Silvernick
Thank you. I guess I'll give it a try.
#6 Posted : Monday, May 21, 2012 5:57:14 PM(UTC)
Silvernick
#7 Posted : Thursday, May 24, 2012 8:01:48 PM(UTC)
Silvernick
I ordered the igniter and was going to install it tonight. The original igniter has high temperature tape wrapped around the wire nut connectors. I have a couple of questions that weren’t answered in the video.
[FONT=Calibri","sans-serif]Can the wire nuts be reused? There weren’t any included with the new igniter. Also, do I need to wrap the wire nuts with thehigh temp tape? I wasn’t able to find anything similar at the store tonight.[/FONT]
[FONT=Calibri","sans-serif]Thank you,[/FONT]
[FONT=Calibri","sans-serif]SilverNick[/FONT]
#8 Posted : Friday, May 25, 2012 2:39:53 PM(UTC)
If the original wire nuts are made of porcelain then you can reuse them. Otherwise you should order them. You don't need any tape.
- The high temperature porcelain wire nuts Part number: AP3440631
Silvernick
#9 Posted : Friday, May 25, 2012 6:22:11 PM(UTC)
Silvernick
The wire nuts are porcelain so I just reused them. I lit the oven 3 or 4 times without fail so the igniter appears to have corrected the problem.
Thank you
#10 Posted : Saturday, May 26, 2012 12:56:39 PM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Lower Oven doesn't heat properly (Oven Repair (including Ranges and Cooktops))
by Softballfan 4/16/2016 1:45:41 PM(UTC)
fridgidaire oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by debshroom 5/8/2013 7:15:43 AM(UTC)
upper oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by stephen36 2/25/2013 11:57:09 AM(UTC)
Oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by bobby6432 10/26/2012 3:28:27 PM(UTC)
Whirlpool SB130PER4 Gas Wall oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by sikhnerd 10/17/2012 10:00:32 AM(UTC)
by dskar 6/10/2012 5:16:27 AM(UTC)
oven doesn't heat to selected temp. (Oven Repair (including Ranges and Cooktops))
by jimsmithbc 10/31/2011 1:54:50 PM(UTC)
Magic Chef gas oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by jand 7/1/2011 9:23:12 AM(UTC)
Oven doesn't heat after bright flash (Oven Repair (including Ranges and Cooktops))
by markmelancon 6/17/2011 11:10:57 AM(UTC)
Electric Range oven doesn't heat - stove top works (Oven Repair (including Ranges and Cooktops))
by deannastevens70 3/2/2011 8:54:15 PM(UTC)
GE Oven doesn't heat after using self clean (Oven Repair (including Ranges and Cooktops))
by Elmo1 2/3/2011 4:57:50 PM(UTC)
GE oven doesn't heat up everytime (Oven Repair (including Ranges and Cooktops))
by IntermittentGE-Oven 12/20/2010 3:49:12 PM(UTC)
Magic Chef oven doesn't heat (Refrigerator & Freezer Repair)
by Francisco Dan 12/7/2010 12:46:57 PM(UTC)
Oven doesn't heat to temperature (Oven Repair (including Ranges and Cooktops))
by msdahl 11/5/2010 11:41:01 AM(UTC)
