firefly
#1 Posted : 13 years ago
firefly
originally saw sparks from control panel. left us with no spin cycle.
I replaced the timer. The machine will click on for load and rince, but I get nothing on spin. What's up?
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Please describe more detailed what is the washer doing.
Simon.
firefly
#3 Posted : 13 years ago
firefly
The control panel was loose from the machine. Wife asked me to reattach, but I told her to use it as is until I got to it. She began seeing sparks from back of the control panel when she began a load. I observed sparks as the cycles changed. I replaced the timer, but now washer fills and does NOT agitate or spin. It just sits there full of water. Just like before, but without sparks.
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
First of all check all the wires inside the control panel.
Next, check the continuity of the lid switch. Less then 1ohm between Gray and White with the lid closed. You can install the jumper wire for the "life" test.
Next, check continuity at the water level switch contacts V to T. With tub full of water should read less then 1 ohm.
The lid switch Part number: 8318084
The water level Part number: W10339251
Here are the breakdown diagrams and Replacement parts for Maytag MTW5620TQ1 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
firefly
#5 Posted : 13 years ago
firefly
simon, sorry but I don't understand how to install jumper wire for "life" test. I don't know what you mean. Can you guide me?
Simon / APP Team
#6 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi, Firefly.
Get a 5in electrical wire 14 gauge or so, strip 1/4 in off each end.
Unplug the washer.
Incert jumper ends into lid switch terminals with Grey and White wires.
Plug in washer and start the cycle.
To do all this you need to open the control panel.
Thank you.
Simon.
firefly
#7 Posted : 13 years ago
firefly
simon, I have followed your instructions and jumped the lid switch. Everything seems to be working. I will asume this means I need a new lid switch. I would also like to know if we could do a couple of loads while waiting for the part, or am I risking further damage? Thanks for all your help.
Simon / APP Team
#8 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
I don't think that you will damage the washer more then it's already, but there is a very serious risk of getting hurt by reaching into a spinning tub.Consider that.
Thank you.
Simon.
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9 years ago
No spin cycle on washer...need help (Washer Repair)
by 1moretoy 10 years ago
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 10 years ago
no spin cycle so clothes stay wet (Washer Repair)
by pmt1231 11 years ago
Maytag Atlantis No Spin Cycle Replaced Thrust Bearing. (Washer Repair)
by MarkBe 11 years ago
kenmore ~ no spin cycle (Dishwasher Repair)
by chrismo13 12 years ago
No Spin Cycle (Washer Repair)
by KJH1961 12 years ago
No spin cycle (Washer Repair)
by baldguywithagoat 12 years ago
I replaced maytag mav6200aww brake, now no spin cycle (Washer Repair)
by jmlaudate 13 years ago
Washer tumbles but no spin cycle (Washer Repair)
by jrwhitton 13 years ago
Tumbles but no Spin Cycle (Washer Repair)
by Rob2001 13 years ago
by John Foley 13 years ago
No spin cycle or drain? Lid switch? (Washer Repair)
by 9n1Ed 13 years ago
GE washer no spin cycle (Washer Repair)
by fsuglover 13 years ago
Maytag no spin cycle (Washer Repair)
by Cclcectcmc 13 years ago
