I have a Thermador model smw272 with a built in microwave
It does not heat well. It is losing the ability to heat food at the same rate that is has in the past.
I tested the temp rise with 32oz of water and the temp rose 12 degrees in one min on high power.
Do the magnetrons lose power over time or do I have another issue.
Thanks for the help
Mike
Groups ready for retrieval: APP Team
Hi.
Yes, the magnetron may lose the power over the time.
Please provide the complete model number.
Thank you.
Simon.
It is a Thermador SMW272P oven.
The microwave is built into the unit and upon further inspection its magnetron is a Panasonic 2M261-M32
Mike
Hi. The microwave you have is using an inverter power board, which is no longer available. The chance that it's the magnetron is 50/50. Try to replace it. If it will work - you are lucky. The good think that you can return any parts even if they been installed. The magnetron Part number: 487757
Replaced the magnetron and the unit condition remains the same.
Time for a new microwave. The GE JEB1860SMSS has the same dimensions as the Thermador model 11 15 157 microwave.
Thanks for the help
Mike
That's a 16 11 157 Thermador microwave I'm replacing.
