Kashif ikram
#1 Posted : Sunday, March 22, 2009 4:07:41 PM(UTC)
Kashif ikram
My gardage disposal is jammed. I can move blades freely but it keeps making the humming noise. I alos cannot unjam it with te wrench. I tried pretty hard to unjam it but no luck.
Any idea?
#2 Posted : Monday, March 23, 2009 5:34:06 PM(UTC)
Rank:: Advanced Member
Unplug the garbage disposer and using a flash light look inside through the top. Most likely there is a metal screw stuck or something similar to it.
ehags
#3 Posted : Wednesday, June 24, 2009 4:00:02 PM(UTC)
ehags
I have a Maytag garbage disposal model #DFC3000AAX-1. It is whirling around but doesn't sound like blades are going. I pulled out all debris with tongs. I also used the wrench both ways and hit reset button but nothing improved. Does this mean it needs to be replaced? Please send me suggestions. Thanks
#4 Posted : Wednesday, June 24, 2009 5:51:43 PM(UTC)
Did the blades move when you used the wrench? Using a flash light try to inspect the blades and the nut in the center.
besmer
#5 Posted : Sunday, August 9, 2009 5:41:37 PM(UTC)
besmer
Okay, I found out there is a screw stuck in my disposal, how do I remove it? I tried pulling it out with a needle nose pliers, but there isn't enough room in there to really make sure it is in the right place. Should I remove the disposer?
#6 Posted : Sunday, August 9, 2009 7:36:29 PM(UTC)
If nothing else works then this probably the only solution.
