rad1026
#1 Posted : Tuesday, March 17, 2009 6:00:22 PM(UTC)
rad1026
We had a voltage spike in our home this weekend that completely killed the display panel LED and all face plate functions. I pulled the display panel and tested the 15 amp fuse , the fuse is fine. I noticed on the panel circuit board that a small blue capacitor was burned. I removed the capacitor from the circiut board and replaced it. Now the display board is alive but all it shows is 888:88 which shows on the tech sheet that "all switches are opened". I don't know what that means. The complete board on this unit is expensive. I replaced the capacitor for $1.89. Is there any other testing I can do to determine what the opened switch display is telling me?
TechnicianBrian
#2 Posted : Tuesday, March 17, 2009 6:35:05 PM(UTC)
TechnicianBrian
Make sure the ribbon cable to the touch panel is fully seated and maybe even clean the ends with an pencil eraser. If the board will not reset with a key press, there may be more serious damage than first thought.
rad1026
#3 Posted : Wednesday, March 18, 2009 6:08:09 AM(UTC)
rad1026
I will try that tonight Brian, thanks. I'll let you know.
rad1026
#4 Posted : Wednesday, March 18, 2009 6:12:28 AM(UTC)
rad1026
Out of curiosity Brian, the replacement board part says Out of Stock but normally ships in 5-6 days, does that mean its still available but ships from the factory or does that mean it is out of stock and I could be waiting a while if it is even available any more.
TechnicianBrian
#5 Posted : Wednesday, March 18, 2009 4:09:36 PM(UTC)
TechnicianBrian
Out of stock is usually a factory or issue and can ship very quickly or may be on a back order depending on the situation. It will still be available, just not a same day / next day type of shipment.
rad1026
#6 Posted : Thursday, March 19, 2009 6:56:25 AM(UTC)
rad1026
Brian, dude, you are the man. I cleaned the ribbon contacts up and put the board back in place. Everything works properly. Man, you saved me $$$$. Thank you so much for the help. If you ever get to albuquerque, I'd like to pour you a beer. cheers!
TechnicianBrian
#7 Posted : Thursday, March 19, 2009 10:37:37 AM(UTC)
TechnicianBrian
Glad it worked out for you. Don't get down south much past Vegas, but if I find my way down your way, I'll look you up.
