magman12
#1 Posted : Friday, April 6, 2012 5:40:12 AM(UTC)
magman12
All components work but no heat. Bought a new diode but not the problem. Primary voltage on transformer correct. Is there any way to safely check the output of the transformer? Secondary is 82 ohms. Magnetron shows 1 ohm or less. Connected a 1/8" spark gap on the disconnected magnetron leads but no spark.
thanks.
Simon / APP Team
#2 Posted : Friday, April 6, 2012 9:58:10 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is bad magnetron.
The magnetron Part number: AP4439646
Thank you. Post the results.
Simon.
