All components work but no heat. Bought a new diode but not the problem. Primary voltage on transformer correct. Is there any way to safely check the output of the transformer? Secondary is 82 ohms. Magnetron shows 1 ohm or less. Connected a 1/8" spark gap on the disconnected magnetron leads but no spark. thanks.
Groups: APP Team
Hi. Most likely the problem is bad magnetron. The magnetron Part number: AP4439646
Thank you. Post the results. Simon.
