misssue
#1 Posted : Friday, January 23, 2009 11:21:28 AM(UTC)
misssue
does anyone know where i can get a service manual i took the back off an don't see anything like what the pics is showing me when i put in the model # an type of dryer thanks for any help
SublimeMasterJW
#2 Posted : Friday, January 23, 2009 12:50:41 PM(UTC)
SublimeMasterJW
ESC_GSC_Service Manual.pdf (1,758kb) downloaded 42 time(s).You access the dryer by using a butter knife to compress those clips holding down the top. The heater is located in the back and is the same as a PYE model.
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : Friday, January 23, 2009 12:57:06 PM(UTC)
SublimeMasterJW
To Pop that Top begin here:
Doc1.doc (26kb) downloaded 10 time(s).
Not that beer can top now
That will be AFTER you fix the dryer:D
SublimeMasterJW
#4 Posted : Friday, January 23, 2009 1:03:33 PM(UTC)
SublimeMasterJW
A typical element for a Crosley dryer:
How to remove the washer cabinet.doc (248kb) downloaded 28 time(s).It also comes with a high limit and it is recommended you replace it. It mounts above the heater and needs to
come off to get to the heater.
BsA
#5 Posted : Tuesday, March 17, 2009 2:22:20 PM(UTC)
BsA
How do I get to the igniter for a Crosley gas dryer ?
Admiral Dryer Runs no heat in heat cycles, does not turn on in no heat fluff (Dryer Repair)
by jennshuey 11/18/2016 11:06:43 PM(UTC)
Gas Dryer Runs No Heat (Dryer Repair)
by zinger 12/7/2012 6:41:31 PM(UTC)
dryer runs no heat (Dryer Repair)
by Jim Bags 8/31/2009 7:41:27 PM(UTC)
Timer does not advance dryer runs no heat (Dryer Repair)
by Rmelc1 7/20/2009 1:25:42 PM(UTC)
Dryer runs no heat, Please help (Dryer Repair)
by blindman 5/17/2009 6:30:38 PM(UTC)
by kwclark 1/24/2009 8:21:09 AM(UTC)
Dryer runs no heat (Dryer Repair)
by jays327 1/23/2009 3:31:24 PM(UTC)
by glennb 8/10/2007 9:19:09 AM(UTC)
by Wesley 7/24/2007 12:54:40 PM(UTC)
