misssue
#1 Posted : 16 years ago
misssue
does anyone know where i can get a service manual i took the back off an don't see anything like what the pics is showing me when i put in the model # an type of dryer thanks for any help
SublimeMasterJW
#2 Posted : 16 years ago
SublimeMasterJW
ESC_GSC_Service Manual.pdf (1,758kb) downloaded 37 time(s).You access the dryer by using a butter knife to compress those clips holding down the top. The heater is located in the back and is the same as a PYE model.
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : 16 years ago
SublimeMasterJW
To Pop that Top begin here:
Doc1.doc (26kb) downloaded 5 time(s).
Not that beer can top now
That will be AFTER you fix the dryer:D
SublimeMasterJW
#4 Posted : 16 years ago
SublimeMasterJW
A typical element for a Crosley dryer:
How to remove the washer cabinet.doc (248kb) downloaded 24 time(s).It also comes with a high limit and it is recommended you replace it. It mounts above the heater and needs to
come off to get to the heater.
BsA
#5 Posted : 16 years ago
BsA
How do I get to the igniter for a Crosley gas dryer ?
Admiral Dryer Runs no heat in heat cycles, does not turn on in no heat fluff (Dryer Repair)
by jennshuey 8 years ago
Gas Dryer Runs No Heat (Dryer Repair)
by zinger 12 years ago
dryer runs no heat (Dryer Repair)
by Jim Bags 15 years ago
Timer does not advance dryer runs no heat (Dryer Repair)
by Rmelc1 16 years ago
Dryer runs no heat, Please help (Dryer Repair)
by blindman 16 years ago
by kwclark 16 years ago
Dryer runs no heat (Dryer Repair)
by jays327 16 years ago
by glennb 18 years ago
by Wesley 18 years ago
