2 Pages12>
scruffydog
#1 Posted : Tuesday, November 20, 2007 4:01:24 PM(UTC)
scruffydog
I have a range that displays F1 error code ONLY when in self cleaning mode after 1 1/2 hrs. Otherwise range works perfectly. When attempting to buy EOC part on ApplianceParts website, there are similar model numbers as PLCS389DCB but none exact. This slide-in range has a gas stove top with an electric convection oven. Is this a special oven and I have to get part from manufacturer? Or can you recommend other vendors?
Thanks!
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
#2 Posted : Tuesday, November 20, 2007 4:50:28 PM(UTC)
The first thing I would recommend to replace is the oven temperature sensor (aka the temperature probe), not the EOC. Also check the wire harness from the sensor to the EOC.
- The part number for the oven temperature sensor AP3363354
- The part number for the EOC (just in case) AP3581500
scruffydog
#3 Posted : Tuesday, November 27, 2007 3:36:57 PM(UTC)
scruffydog
Thanks Gene!
If the problem is the temperature sensor as you indicate, wouldn't the unit generate a different failure code?
A different way to ask the same question: How accurate / reliable are the oven error codes?
#4 Posted : Tuesday, November 27, 2007 3:49:45 PM(UTC)
They are pretty accurate but you have to know how to understand them.
judy shultz
#5 Posted : Tuesday, November 27, 2007 4:30:39 PM(UTC)
judy shultz
how can I get a manual for my gallery stove? Someone gave it to me but no instructions . I'm trying to clean the self cleaning oven but......
#6 Posted : Tuesday, November 27, 2007 5:03:33 PM(UTC)
I need the complete model number of the product.
Post it as a new thread, please.
scruffydog
#7 Posted : Thursday, December 13, 2007 12:30:15 PM(UTC)
scruffydog
I'm going to try to repair this. Because of the tight fit, I'd rather not slide out this unit to repair it if I don't have to. To access the EOC and inspect wiring harness, could I just remove the top? Is this possible?
Are there disassembly instructions available somewhere?
#8 Posted : Thursday, December 13, 2007 6:03:27 PM(UTC)
I'm afraid you would not get full access to the oven sensor and its wires from the front of the unit.
You can try.
And forget about EOC for a while. Do the oven sensor first.
kawfeeman
#9 Posted : Thursday, December 13, 2007 6:29:33 PM(UTC)
kawfeeman
if you goto Frigidaire.com, usually somewhere around the customer support tab, there is a way to get manuals for most models ( have exact model # )
jim
scruffydog
#10 Posted : Thursday, December 27, 2007 10:20:38 AM(UTC)
scruffydog
Replacing the oven probe cured the problem.
Thanks Gene!!
2 Pages12>
