gmeyer555
#1 Posted : Sunday, March 15, 2009 10:41:27 AM(UTC)
gmeyer555
Faster to replace handle and door frame, or replace complete door assembly? And how to repair?
TechnicianBrian
#2 Posted : Sunday, March 15, 2009 11:08:58 AM(UTC)
TechnicianBrian
The way the door on your microwave mounts, I would replace the handle myself. Basically you need a putty knife and while working around the edge of the door, you need to remove the inner frame called a choke over, then you can remove the outer panel leaving the middle metal portion of the door. Both parts are held in place by plenty of plastic tabs so you need to start at one point and work your way around until the parts come off. If you break a tab or two, not a big deal, just don't damage the metal portion with your tools.
gmeyer555
#3 Posted : Monday, March 16, 2009 12:09:56 PM(UTC)
gmeyer555
The removal of the choke over panel took 5 minutes only broke 1 tab. Only need to order and install parts. Wonderfull instructions.
TechnicianBrian
#4 Posted : Monday, March 16, 2009 2:19:19 PM(UTC)
TechnicianBrian
Only one tab. That's better than I usually do. Glad I could help.
Repair Door spring/pulley ( holds door open ) (Dishwasher Repair)
by thdun001 11/5/2011 10:38:34 AM(UTC)
how to repair door gasket (Refrigerator & Freezer Repair)
by marieburse 9/9/2011 11:59:27 AM(UTC)
Dishwasher -how To Repair Door Spring (Dishwasher Repair)
by ermases 10/16/2008 5:38:05 AM(UTC)
repair door spring (Dishwasher Repair)
by Sdemarais 11/18/2007 10:40:58 AM(UTC)
