6 Pages123>»
littlechi
#1 Posted : Tuesday, November 27, 2007 7:04:07 AM(UTC)
littlechi
I don't know why only the dishes on lower rack cleaned but not the upper rack. I already checked all the spray arms, they are not clogged.
Any idea?:confused:
#2 Posted : Tuesday, November 27, 2007 4:08:02 PM(UTC)
Most likely the problem is a foreign objects inside the pump chopper and the pump inlet protector, causing not enough pressure in the wash system.
Remove the top cover and the inlet protector cover and clean everything.
littlechi
#3 Posted : Monday, December 10, 2007 1:23:23 AM(UTC)
littlechi
There are 3 screws at the bottom I already unscrewed. I have no clue how to take them apart.:mad:
richappy
#4 Posted : Monday, December 10, 2007 2:31:57 AM(UTC)
richappy
You can go to applianceaid.com to get info. Look for a half round pump housing cover, remove screw and pry off, you will find the screen in there.
#5 Posted : Monday, December 10, 2007 9:55:11 AM(UTC)
Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm.
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1 on the break down diagram).
Remove the inlet protector (#8) holding by the tab on the right side.
Check the chopper (#6) for any clog.
Clean all debris and assemble in the reverse order.
richappy
#6 Posted : Thursday, December 13, 2007 12:05:03 PM(UTC)
richappy
Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
The check valve is on the right side of the chopper, a black thing stuck in the housing.
Check valve P# 8268375; chopper assy. P# 8268383
littlechi
#7 Posted : Friday, December 14, 2007 6:33:47 AM(UTC)
littlechi
After I cleaned and reasembled everything, the clean light is flashing.
Please help.:mad:
#8 Posted : Friday, December 14, 2007 9:53:38 AM(UTC)
Reset the control as described in the technical sheets.
littlechi
#9 Posted : Saturday, December 15, 2007 4:20:29 AM(UTC)
littlechi
You guys are AWESOME !!!!!!!!!!!!!!!!
I give you guys grade : A++++++++++++++++
My dishwasher working perfect.
Thanks.:) :) :) :)
richappy
#10 Posted : Saturday, December 15, 2007 5:54:52 AM(UTC)
richappy
Don't count your blessings yet: If your chopper fails in the future, you will need to pull the dishwasher and replace the pump impeller.
Guest (5)
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
6 Pages123>»
