6 Pages<1234>»
DavidN6DF
#11 Posted : Wednesday, December 26, 2007 9:34:43 PM(UTC)
DavidN6DF
Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm.
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1 on the break down diagram).
Remove the inlet protector (#8 on the break down diagram) holding by the tab on the right side.
Clean all debris and assemble in the reverse order.
the screws for the cover on my Whirlpool GU2500 sre not the slotted type shown in the diagram but some sort of hex type. I couldn't find an allen wrench to fit. Any idea what type of tool is needed?
richappy
#12 Posted : Thursday, December 27, 2007 1:34:16 AM(UTC)
richappy
You will need to buy a set of torx bits for these.
DavidN6DF
#13 Posted : Thursday, December 27, 2007 3:46:23 PM(UTC)
DavidN6DF
:) Thanks for the suggestion about torx bits!
jlp7534
#14 Posted : Saturday, March 14, 2009 6:11:03 AM(UTC)
jlp7534
I have a Kenmore model 66517514200 and I think the Chopper is the problem. However, I can't get the inlet protector off to get to the chopper. I removed 2 screws and can't see any others. It will not budge and I don't want to damage the part trying.
Can someone help with this? Thanks.
#15 Posted : Saturday, March 14, 2009 12:41:47 PM(UTC)
Rotate the screw-end of the protector upward to remove the part and expose the chopper assembly.
richappy
#16 Posted : Saturday, March 14, 2009 2:17:03 PM(UTC)
richappy
I use a flat bladed screw driver to pry on the right side of the half round chopper housing, eventually it will work loose. Usually a build up of soap residue makes it stick. If the chopper screen is clogged, you will need a new chopper and check valve in the bottom of the housing.
BrianT267
#17 Posted : Monday, April 13, 2009 10:58:22 AM(UTC)
BrianT267
Originally Posted by: richappy Go to Quoted Post
Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
The check valve is on the right side of the chopper, a black thing stuck in the housing.
Check valve P# 8268375; chopper assy. P# 8268383
Hello all I was following this procedure and found a part 8268297 it is a small white plastic coneshapped item. I'm not sure where it came from I was wiping out the bottom and found it. I think it may have fell from the top where the upper water feed is. Help! I don't want to put back together with extra parts.
thanks:eek:
BrianT267
#18 Posted : Monday, April 13, 2009 11:15:33 AM(UTC)
BrianT267
thanks:eek:
Never mind i found it it does go in the upper water feed i think it is a nozzle. Putting the chopper back in and getting it to engage the impeller is a bear.
BrianT267
#19 Posted : Monday, April 13, 2009 11:54:58 AM(UTC)
BrianT267
I put it back together and it still does not work. What is the next step? the chopper had scum on it but turned as did the impeller. The check valve looked ok it was intact I don't know if the rubber gets stretched out over time. Should those to things be replaced or is there something else to look at?
richappy
#20 Posted : Monday, April 13, 2009 12:17:39 PM(UTC)
richappy
What was the original problem, no water pressure? If so, you might have a pump motor running backwards!
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
6 Pages<1234>»
