tom
thongluong
#1 Posted : Monday, March 26, 2012 2:01:23 PM(UTC)
thongluong
I Have a Ge Monogram Compactor. Right now when you hit run it is going down then keep cliking but not pullup, I have to turn off and hit run again to make it going up. What part that cause these problem. Please let me know so I can buy the part to fix it.
Thanks,
#2 Posted : Monday, March 26, 2012 4:58:39 PM(UTC)
Will the key switch return from the Start position to the Run position by itself?
Check the key switch for continuity between the "V" & "Y" terminals while the switch is in Run position. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric ZCG3300VWW-01 TRASH COMPACTOR | AppliancePartsPros.com
thongluong
#3 Posted : Saturday, March 31, 2012 3:36:59 PM(UTC)
thongluong
I open the swicth, there is 120V beetween Y and V, T-R and V. When I turn the switch to ON, there is no voltage beetween these switch. the motor lower the plate and it is not moving back up and keep ging a clicking noise, the knob is not turn back to OFF position. I have to manual to back to OFF and Then ON again so the motor can rising up to the top.
#4 Posted : Saturday, March 31, 2012 7:24:04 PM(UTC)
The switch with terminals "V" & "Y" is what it calls "momentary switch". Such switch must return to to its normal (open) position when released.
If it does not happen, the key switch has to be replaced.
- The key switch Part number: AP2037730
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Whirlpool french door w/ bottom freezer (Refrigerator & Freezer Repair)
by JumperWire 2/11/2024 1:41:25 PM(UTC)
GE GSD2200Z01AD Leaking out front bottom (Dishwasher Repair)
by jappel 1/22/2024 7:02:46 AM(UTC)
Slow agitation and spin with clicking noise in bottom end of machine (Washer Repair)
by Guest 1/13/2024 12:19:08 AM(UTC)
Dual Oven, neither bottom element heating. (Oven Repair (including Ranges and Cooktops))
by Phoenix737 12/9/2023 9:58:17 AM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Stuck bottom pan on gas range (Oven Repair (including Ranges and Cooktops))
by Guest 11/4/2023 12:02:07 PM(UTC)
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
