jtowntbo5@yahoo.com
#1 Posted : Friday, March 13, 2009 7:49:53 AM(UTC)
jtowntbo5@yahoo.com
Dryer heating to around 170 - 180 F. Changed Cycling Thermostat and Thermal Fuse. Is it just the high limit Thermostat that needs changing?
#2 Posted : Friday, March 13, 2009 10:19:29 AM(UTC)
Replacement parts for AMANA ALE331RAW | AppliancePartsPros.com
Could not find a wiring diagram for this unit but perhaps won't need it.
Also not sure where you are measuring the temp.
The high limit should not come into play if all is OK with the dryer, it is a safety device.
Sounds more like you have an air flow problem or if the lower temp settings do not work, the Heater,thermostat Item 11 in the "Motor and fan assembly" section may be burned out.
Not sure what this heater should measure would think about 5,000 ohms.
You are actually sucking the air through the system so poor drum seals etc. will effect temperatures. Also dirty lint filter especially if you use fabric softener, it can coat the screen greatly reducing air flow. If coated it has to be cleaned with soap and water.
Check the vent system.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
kayakcrzy
#3 Posted : Saturday, March 14, 2009 4:17:12 AM(UTC)
kayakcrzy
On that dryer it tends not to have a great venting system. The lint builds up in the blower assembly. You have to remove the front, and then remove the blower assembly, which is held in by Four 5/16th screws. 2 on each side. Tom ApplianceEducator.com
jtowntbo5@yahoo.com
#4 Posted : Saturday, March 14, 2009 6:03:26 AM(UTC)
jtowntbo5@yahoo.com
I'm running the dryer in an open area, inside a warehouse, with no vent pipe, and I have a thermometer in the exhaust. The blower housing doesn't appear to be blocked up.
#5 Posted : Saturday, March 14, 2009 7:41:29 AM(UTC)
Does changing the temp setting change the exhaust temp?
If not you may have a grounded element.
Remove both wires from the element and measure it, should be around 10 ohms. Then measure from each side to the case/frame should be an open (infinite)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
