cyberjones98
#1 Posted : Sunday, March 11, 2012 7:40:13 PM(UTC)
cyberjones98
I have two issues with my KitchenAid electric range model #KESC307HWW8.
1. I boiled over some water and now the display panel is blank. The touchpad still works, just no display. I believe that the control board needs to be replaced? - Part Number: AP3176181
2. When cooking a heavy pot of potatoes, the glass cook top cracked and needs to be replaced. -Part Number: AP3837477
The question is, can a homeowner do these repairs? and where can I find instructions to do this
#2 Posted : Monday, March 12, 2012 5:30:04 AM(UTC)
The board may not need replacing.
Have you tried unplugging the unit for a couple minutes to see if it will reset?
If it still does not work, I would unplug the unit and open it up, then dry the board off with a hair dryer.
Could be that there is just some moisture between a couple tracks or part connections and that is dropping the voltage to the display.
Here is a manual which should help with the repair.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=160
File Attachment(s):
KESC307.pdf (185kb) downloaded 5 time(s).
cyberjones98
#3 Posted : Monday, March 19, 2012 7:56:41 PM(UTC)
cyberjones98
http://appliancejunk.com...wnloads;sa=view;down=160
I reset it, it didn't work :mad: still no display - I'm going to have to replace it
